1 - 9 of 9 Posts
You may be able to chirp with the B&M Shift Improver, you SHOULD be able to spin 2nd and chirp 3rd with the B&M Transpak. Of course, this all depends on rim/tire selection, vehicle weight, etc.
With the Shift Improver, you wil get firmer shifts, but not real harsh. You will still be able to drive in "auto-mode" (3rd/D), while 1st and 2nd will be just that.
With the Transpak, you will be able to up/downshift at any rpm. You will still have "auto mode" (3rd/D), and will still have 1 & 2 manual. The shift with the transpak is much firmer, and if you have the HP/TQ to back it up, you should be chirping 2nd minimum..
get your normal shift kit/shift improver. do it, if its not enough drill the hole out a little more...
Transpak part number is 30228
Shift kit is 30262
Make sure you have a th350 and not a th350c (lockup version)
Both kits are available for the TH350c, but IIRC, will not interchange
Easy way to tell if you have a TH350c is a 4 prong electrical plug on the driver side of the case.
Not a bad tip/hint, but there is more to the Transpak than that.. However, this is what people have been doing for a while (homemade shift kit). There are a few other mods if you're looking to go the "homemade" route. IMO, for someone that hasn't pulled many transmissions apart, the Transpak or Shift Improver are well worth the money.
i do have the 350 non lock up and i will be running 13wit 155/80s and 4.11 gears in the rear the motor is built too
damn have you tried out your rim and tire combo with that gear? seems like you wouldnt need a shift kit
aint gonna be a freeway car so im not to worried bout it. just want sumthing that will put u in the seat fast ;)
x2, If you're planning on staying on spokes, just go with the Shift Improver..... Those gears will put you in your seat, all a shift kit will do is keep you there when the trans shifts...
1 - 9 of 9 Posts
