1 - 20 of 44 Posts
1 1/2 g body uppers stock lowers and caprice spindles wanna get as straight as possible to stop all of the terrible tire ware so i can hit the highway more i go every where in my car locally but wanna know that i can jump on the high way a couple hours and it be all good to
post pics of how and what it looks like to shim and get better life out of the tires and what i gotta do to the suspension to help with this thanks
suspension is off currently getting triple plated but when it gets back i intend to do so
GOFUCKURSELF
U SERIOUSLY DONT KNOW HOW OR WHERE TO PUT SHIMS?? LOOK AT ANY OTHER CAR W SIMILAR SUSPENSION, BUT STOCK ......
just wanted to make sure its done right ;)
GOFUCKURSELF
Ok,HERE GOES.......I RECOMMEND USING GRADE 8 WASHERS INSTEAD OF SHIMS ( IF URBOLTS EVER GET LOOSE U WONT HAVE SHIMS FLYN EVERYWHERE ).
PUT HOW EVER MANY U WANT BETWEEN THE EARS AND SHAFT OF A ARM,....THATS ON THE 2 BOLTS THAT HOLD UR UPPERS ONTO THE FRAME / EARS.
BE CAREFUL, IF UR UPPERS ARENT CUT OUT ENOUGH, BY PULLING THE ARM IN, U MAY HIT THE CYLINDER WHEN CAR COMES DOWN FROM HOPPING.....
i figured it out for ya :biggrin:
sounds simple whats a good number to start with?
GOFUCKURSELF
I ACCEPT CASH AND POSTAL MONEY ORDER,... THANKS ;)
i would go a 1/4 and look at it homie
apperciate it thanks :biggrin: :thumbsup:
Discussion Starter #11
GOFUCKURSELF
Try 3 washers per bolt....will pull in 3/8"... ;)
Discussion Starter #13
7 User(s) are reading this topic (1 Guests and 1 Anonymous Users)
5 Members: .TODD, MUFASA, thuglife, OVERNIGHT CELEBRITY, LOC501
Originally posted by .TODD@Feb 10 2010, 12:36 AM~16568993
like the homie said you gotta be car ful it's something you gonna have to play with
why don't you just swap the spindals back out ???
Discussion Starter #15
so 12 washers
Discussion Starter #16
g bodys bent on me twice caprice are much stronger
if his washers are the same as yours
GOFUCKURSELF
Originally posted by .TODD@Feb 9 2010, 11:38 PM~16569019
so 12 washers
At least ur good at math :ugh:
i like the caprice better my self but would help with what you want
GOFUCKURSELF
Grade 8 that fit that are generally 1/8" thick.....i told him to use grade 8 for a reason
1 - 20 of 44 Posts
