G
Guest
·was wondering if there is "another" rear end i can use thats 1" or so shorter or if shortenin it is my only option?
80' cadillac
80' cadillac
I put g-body rear axle in a glass house....1.5 shorterOriginally posted by One Luv@Sep 19 2007, 03:34 PM~8825800
80' cadillac
Do you need mods or does it fit right inOriginally posted by BlackMagicHydraulics@Sep 19 2007, 01:36 PM~8825818
Originally posted by YellowAmigo@Sep 19 2007, 06:06 PM~8827201
Would this work on a 94 caddy too? that would same me a lot of work on my rearend... :biggrin:
Also do yo know what the gearing difference there is between the 2..... will the differential from the caddy rear end fit the G-body housing?
It would be 3" shorter on each side. A glasshouse rearend is wider than a Caddy rearend. :biggrin:Originally posted by BlackMagicHydraulics@Sep 19 2007, 03:36 PM~8825818
Narrow your stock one. I've done the G-body swap and it doesn't allow you to 3 wheel without rubbing. The upper trailing arm mounts are closer together on the G-body so you will have to build new upper trailing arms or run adjustables. I narrowed my stock rearend on my 81 Bonneville 4" total and it still 3 wheels with 12" rear cylinders without rubbing. The average cost to narrow the housing is $150-$200 then you need to have custom axles made $250-$400. It's worth it to be able to layout with out rubbing or running 14x6". Break bread and do it right you'll be happier.Originally posted by One Luv@Sep 19 2007, 04:34 PM~8825800
80' cadillac
yeah thats what i was thinkin to man, i hate 14x6'sOriginally posted by OUTHOPU@Sep 21 2007, 09:27 PM~8844352
Ya I can't stand when somebody tries to pass it off like "I don't think you can even tell the differance". Anything less than 7" looks like shit. If you want to run 13" and run into caliper clearance issues in the front you can also run a late 70's-early 80's Caprice spindle and brake set up to solve that problem as well. I remember my 82 Coupe not clearing the 13"s that why I figured I'd pass it on to you incase you didn't already know.Originally posted by One Luv@Sep 21 2007, 10:30 PM~8844366
Originally posted by 81 FLEETWOOD@Sep 21 2007, 02:50 AM~8838531
just get real daytons :biggrin:
Well some cars need way more than even a Dayton can cure. Had Daytons back in the day on my Catilina and it still needed the rearend narrowed to work.Originally posted by 81 FLEETWOOD@Sep 21 2007, 02:50 AM~8838531
Sorry I'm not a sheep that does the same cars as everyone else. Caddys, Impalas, G-bodies no thanks I'll do my own thing. No matter what I drive it has 7" wide wheels and 2 doors (if it was an option). That was when I was 17 (real 72 spoke Daytons back then) and I'm 31 now so don't start.Originally posted by 81 FLEETWOOD@Sep 22 2007, 01:48 AM~8845488
CATILINA :uh:
I'm just letting you know where I stand thats all. No hard feelings , I'm no E-Thug.Originally posted by 81 FLEETWOOD@Sep 22 2007, 01:40 PM~8847551
damn homie calm down :biggrin:
65 Catalinas are BADASS. They have some clean ass lines and alot of style.Originally posted by OUTHOPU@Sep 22 2007, 01:08 AM~8844886
