Anyone have experience with that? I want to try it out on the current project. I want to get a super wet look. Oh....and the single stage paint will be brand new too...I'm not just doing over a factory paint. :twak:
YOU sand body work with 500?Originally posted by FWDFleetwood@Oct 20 2006, 03:31 PM~6409737
I usually get a nice shine when the bodywork is sanded to 500 dry, then sand the primer no lower than 600 wet. That usually takes care of the FLA too.
why not just use urethane bs/cc?use a catalyzed bc and get the same result without the heavy overspray and awful smell :barf:Originally posted by big pimpin@Oct 20 2006, 11:11 AM~6407971
Yeah, probably redundant, but I find it easier to not get pinholes.Originally posted by fleetwoodmack@Oct 21 2006, 12:07 AM~6412102
Originally posted by SUPREME69@Oct 21 2006, 12:18 AM~6412679
IF YOUR GONNA SPRAY CLEAR OVER THE SINGLE STAGE WHY NOT JUST USE BASE COAT. MOST SYSTEMS IVE USED RUN THE SAME FOR BC/CC AND SINGLE STAGE. IN SOME CASES THE SINGLE STAGE WAS MORE. YOU CAN GET A DEEP WET LOOK WITH BC/CC IF YOU CLEAR YOUR CAR THEN WET SAND IT AND RESHOOT 3-4 MORE COATS OF CLEAR THEN CUT AND POLISH. BUT THATS JUST MY 2 PENNIES.
