When is the mixing of these bags appropriate?
Depends on the application
What they going in?
1976 cadillac coupe deville (5,200 lbs with V8 500 up front)
Bigger the bag=less psi it takes to lift and you'll get a smoother ride.So yeah if you can get it in there go for itOriginally posted by slickpanther@Jan 18 2010, 11:26 AM~16325764
Since my car is heavy as hell up front would it be more practical to go with RE-8s up front? Would the difference in psi and size of bags make a crappy ride? Basically what I'm asking is should I go RE 8's all around or which ones should I mix match?
thats true, but you need more air (volume) to get the lift. I would try to fit 8's if i was you, but if its just too damn close, I think youll be fine with 7sOriginally posted by baggedout81@Jan 18 2010, 01:10 PM~16326144
I remember talkin to a member on here by the name of SWIPH.He used to have a mini truck cant remember what it was off hand but he had like a 2800 firestone in it.He said that fucker would lift at 20 psi.To bad he's taking a vacation for awhileOriginally posted by Fine59Bel@Jan 18 2010, 05:58 PM~16329585
different size bags is always the case when dealing with what fits/you can make fit on any vehicle. Mixing isn't really a question for it, to truly mix bags is when either you use different company brands, or different pressure rated bags (ex1. firestone 2600 bags up front, Slam RE7's rear; ex2. Slam RE7's up front Slam XS7 in the rear). Since both bags are RE, it doesn't matter that you mix and match sizes, they will both do 200 psi max.Originally posted by slickpanther@Jan 18 2010, 08:05 AM~16324611
if you can get 8" bags all around the better, if you can't, then it is what it is unless your down to mod for the bag to fit.Originally posted by slickpanther@Jan 18 2010, 11:26 AM~16325764
Your question should have been about which size will fit/should you use for said vehicle.
- having an 8" bag isn't much different from having a 7" in the back. Since it doesn't really weight as much as the front does, your basically putting a little more excess where it's not needed. If you can get an 8" bag up front, you will notice more of a difference in the ride because that 8" bag is taking up where the 7" can't due to the weight of the engine. imo.
