in the tech area, in plumbing, it shows how to plumb slow downs for oil returning to the tank so that you can control the speed at which you dump the ride. Can you plumb in slow downs to control the flow TO the cylinders or is this done another way.
Just wonderin because say if you had a setup where you liked to hop from time to time, then this setup would require lots of volts to the front which in turn will make the front rise really quick. What would you do if you wanted the front to lift nice and slow, but still be able to hop when you want.
Slowdowns?????
Slowdowns?????
