1 - 15 of 15 Posts
I'm a real
2 Things... but here is my setup first: 2 pumps, 8 batts and 3 solenoids to each pump...
1. Do I have dead batts? Batts haven't been charged in about a month and were dead then. Now they are charging too fast... :dunno:
2. When I hit any switch I see little sparks on a couple of solenoids. 1 spark from a solenoid to the front pump and 1 spark from a solenoid to the back pump.
I know this might be vague, but I hope you all can make something out of this.
Thanks!
59 imp 64 imp 77 mc
make sure everything is tightend down.
make sure your noids are not attatched to the floor with sheetmetal screws :uh:
How would that affect it?
Originally posted by steamboat+Jan 21 2004, 01:01 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (steamboat @ Jan 21 2004, 01:01 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--rollin low in a grand prix@Jan 17 2004, 03:46 PM
How would that affect it?[/b][/quote]
its a poor ground...for one the screws loosen and the other is the body is a poor ground...always use the frame for a ground
I'm a real
Discussion Starter #13
Originally posted by LEGACY@Jan 22 2004, 03:18 AM
Batts haven't been charged in about a month ,bad batt's
Yeah I am thinking that a couple of dead... the grounds are fine and so are the noids... Back to the batts. :angry:
Thanks for all the help everyone!
SORRY HOMIE IMMA BOUT TO BORROW YOUR TOPIC FOR A BIT IF U DONT MIND ;) WERE ALMOST ON THE SAME LINE..........MY SET UP WAS WORKING GOOD WELL UNTILL MY REAR HOSE BLEW ....OIL ALL OVER MY TRUNK ....NOW MY SOLINOIDS JUST CLICK . IM NOT GETTING POWER THROUGH THE SOLINOID :dunno: (ONE END OF THE SOLINOID TO THE BAT HAS POWER SO I KNOW THE BATTS HAVE JUICE AND AND I HAVE SWITCH POWER BUT WHEN I PUT THE TEST LIGHT TO THE OTHER SIDE OF THE SOLINOID WHERE IT LINKS TO THE OTHERS..................NOTHING :confused: ............MY MOTOR IS NOT BURNT EITHER BECAUSE THE PUMP WORKS ON DIRECT CONTACT WITH THE BATTS......WHAT DO U GUYS THINK ..........OIL FUQED UP MY SOLINOIDS :dunno:
I think you should replace the bad noids :uh:
1 - 15 of 15 Posts
