1 - 20 of 26 Posts
how long do you usually wait until you swap your solenoids for new ones.... i've had 6 noids going to the front of my car, seeing 96 volts, for 2 years, and im thinking its time to change them... any input?
Originally posted by Johnny562@Mar 10 2010, 02:46 PM~16850864
If it ain't broke, don't fix it!
yea i dont want the front to stick at 96v thats a FIRE right there ;)
I chance mine once a month in the summer as well as rotate my front motors to the rear and new in the front never have to worry about breakin down! :cool: :cool:
once a month?!?!?! holy shit!! i think thats too often
I'd pull them out and put fresh ones in and keep the others for back pumps or sell them half price to someone who needs noids for low voltage setups
Phoenix Chapter President
best advice yet on this thread........and im sure you have a quick disconnect,even at 96v you'll prevent a fire by pulling it befor it even starts........
I did a car that has had the same 3 Accurate solenoids for 7 years now on 108 volts most of the time.
im low volts id be interestd in a couple of them.
Why are solenoids ran in groups of 3 in series?
Why not run them in groups of 3 in parallel?
To me running them in parallel would spreed the load out more on the contacts.............wouldnt that make them last longer?
sorry for jacking the topic but that is somthing I have been thinking about.
you can't ,because the ground for the solenoid is the bracket that holds the solenoid to the rack....power is running thru.....no way of running it in parallel homie.....thats if were talking about accurite's...
You are right, they SHOULD be in parallel to divide the current, but at higher voltage the solenoids "weld " or stick. With three in a series, one or two can stick, and and everything still works fine.
I think individual solenoids stick and unstick alot more than we would like to believe, but with 2 others in series to "back them up" we never even know it.
I use "series-parallel" to split the current on my car. The front uses 13 solenoids. (One turns the other 12 on.)
yeah im talking about accurites, but not running a + to - to a + and so on.
(On the contact side)
What im saying is run your power in on one side on all of them "chained" together and chain all of them together on the other side of them for the output.
remember their is a coil opreated by 24volt that opens and closes contacts that can have any amount within reason going through them.
Maybe im wrong but the contact are what wears out and sticks......so im thinking if they are run in parallel it would prolong the life.
WOW........so your using 1 solenoid contact to run 12 coils?
Im not to sure what to think about that. I guess Ill just go to bed and think about that for a bit.
Thanks
over it
Thanks
It's used as a relay to provide a strong voltage signal to the pump solenoids for faster more reliable responce.
Thanks
yes like a noid to pre noid da noids but at 36volts and hussssssh
post pics of your setup........
ive seen quite a few people using 36v to turn on their front pump solenoids..seems to be a popular voltage...
1 - 20 of 26 Posts
