I am running 2 accurate solenoids per [email protected] a 4 pump pro-hopper system
i am using 6 batts. 2 banks of 36.
so all the batts go flat together, and re-charge together. i have linked the 2 36v possitives together with another cable.. this has given me more speed/power..
I keep losing the first solenoid of the 2/pump, regularly..
on just the rear pumps ..
not sure which ones are front/rear but i know that i have 2 #6 pumpheads and 2#8's.
THe solenoid just clicks..what causes this.. is it just too much power. It works for a couple of weeks fine.. then just stops..
i am confused... thought accurates were the best!!
I know its just the one, because i have replaced it before..
are you keeping your batteries charged? running them low will cause the probablem you described. also check the mounting area for the soleniods you keep loseing, does it make good contact. if not the bad ground conection could be the probablem.
