ok i just recieved two 15" speakers off brand
and i have a huge trunk i have no clue how to figure out the math i used a car audio website caluaclter but still don't understand
can anyone help me here
stats
15" Boyds Sounds
normal impedance 2ohms
splo @ 2.83v 97.87db
fo 28.44 hz
qts .44
vas 10.91
xmax 6.38mm
basket displacement 419.5 cu in
what kinda box you building...sealed or ported
stats
15" Boyds Sounds
fo                              28.44 hz
qts                            .44
vas                            10.91
xmax                        6.38mm
We need some more info on your end....
What is the maxximum outer dimensions for the box?
How much power will be supplied?
What thickness wood are you using?
48" across and 20" high depht is open
amp wise i dunno what amp to use yet i have an old alpine for mow but it's only 80 wats bridged
3/4 mdf
i have two 15" but they will be in seperate boxes
if your ganna build a sealed box and it gonna be just a rectangle then take 3/4" off each outter dimension so if the total length of the box is 34 inches take 2 1/4" off the length 1 1/2'' for the 2 sides and 3/4 for the divide if its 20 inches tall then take off an 1 1/2'' and if its 14'' deep then tale off 1 1/2'' so you will multipy lxhxw
so it will be 31.75x18.5x12.5 this may not b exaclty how u build it but it gives u an idea after you multiply them all together then divide the total by 1728 cause theres 1728 sq inches in a sq foot then divide that by 2 and u wil have the cu ft that u need in each chamber the total sq ft in the box for these example measurements would be 4.24 sq ft and it would be 2.12 cu ft inside each chamber
my plan changed a little i am going with a ported box and both subs in a bow i wanted to get the spl specks on the speakers d boy helped me out
thank you low down your info helped me out also
