i have a 1965 impala and the speedometer doesnt work i replaced the cable and the speedometer gear and it still doesnt work if i spin the gear by hand you can watch the speedometer move what would cause this it is a 2 speed power glide if that matters.
You could always attach a varible speed drill on the tranmission end and run it at a low speed... Have a friend watch the speedo to see if it is registering more than what your hand can produce. To test the other end connect to the trans, route the cable where you can see the other end and take it around the block to see if it is turning.
