1 - 3 of 3 Posts
I NEED SOME HELP I BEEN TOLD I CAN PUT CAPRICE SPINDLES AND A ARMS ON MY CUTLASS TO GET A HIGHER LOCK UP THOSE THIS WORK DOES IT AFFECT ANYTHING WITH THE TIE RODS OR WHAT PROBLEMS CAN I RUN INTO NEED SOME FEEDBACK ...... THANKS
youll have to cut the top plate out of the upper a arms then use the g bodys a arm thru rod and bolt that to the caprice arms...when u do that i will bend ur a arms side plates inwards...once they are bolted to that bar then add a top plate over the a arms and that will hold it in place...easiest way to make caddy/caprice arms fit...
1 - 3 of 3 Posts
