21 - 40 of 48 Posts
Originally posted by NaptownSwangin@Sep 24 2006, 10:57 AM~6234195
Can we get more info on the SHRINK?
Since noone will tell us about the split.....:uh:
man its the same thing, people are going to be REAL confused now.
:roflmao: :roflmao: :roflmao:
~Individuals CC~
:buttkick:
the question is what did you guys use to pull the frame back together?
This is what I have understood of the many hints of split belly topics.
~Individuals CC~
When Ron started talmbout Shrinking instead of spreading....I was like, "Huh?"
That is a hell of a theory that would explain why the C-member is caved in . :cool:
good thnking playa. :thumbsup:
Now lets get the official reply from the masters :biggrin:
Originally posted by 94Fleetwoodswangin@Sep 22 2006, 12:24 PM~6224939
Dont know what you did homie but when i did the g body frame it came together perfectly
wish mine did, nothing lines up im almost ready to throw mine off a cliff :angry:
Now should you move the lower A arm pockets out towards the outside of the car to go along with the split or shrink?
Whats next questions about the backdoor pump?
over it
I don't understand why everyone leaves them caved in like that. If you welded a piece over the split then plated the front and back of the engine cradle and made the bottom flat again before putting the whole plate on the bottom it would be stronger. The frame is going to be weakest in the middle since there is less vertical surface to prevent flexing. Just my humble opinion.
Thats the result of modifying the belly
Thank for the info :cool: but that gives me 1 more question, would I be screwing up if I moved the pockets and split the belly?
Originally posted by HydroCutlass86+Sep 22 2006, 03:49 PM~6225125-->
you do awesome work 94fleet  :thumbsup:
[/b]
<!--QuoteBegin-TD Hydros
@Sep 23 2006, 08:19 AM~6228885
x2
Thanks Homies :)
Originally posted by badass 64@Sep 24 2006, 11:45 AM~6234347
I belly splitted a Big Body frame ones
and it sure helps the hop.
But
how you do it is top secret.
:biggrin: :biggrin: :biggrin: :biggrin:
What up Nicke?
that must mess up your body mounts re aligning them i would rather modify the lower arm than a frame thats my 2 cents :biggrin:
What up Nicke?
Timdog, what's up my friend.
I'm doing alot of blacksmith work right now, torch anvil and a giant sledge hammer.
It's fucking amazing what you can do with those thing's.
Sculpturing metal never been so much fun.
I'm all over angle grinders and mig welders. :biggrin:
What about body mounts?
Should you just make the hole a bit bigger or move to the side?
~Individuals CC~
Speak on what you know. If the split is done right, EVERYTHING lines up and you CAN NOT get the same effect by altering the arms. :twak:
These guys are a trip....:uh:
21 - 40 of 48 Posts
