1 - 20 of 23 Posts
I'm going to get some 15" Daytons for my '82 Buick Park Avenue. Should i get standard or Reverse?
Discussion Starter · #13 ·
my stock is 15's, thats why in going with 15's, i know 215/70/15 is stock on towncars but my stock tires are 215/75/15 so they will be alittle lowr. and the reason im going just a little lower is because if i go to much then my tailpipe and bumper will scrape when i back out of my driveway and i have no bags or hydros on my car so thats why i cant go to low. Pak Man can you post a picture of your car or send one to me?
Discussion Starter · #17 ·
with whitewalls? how high is your car sitting? does it have bags or hydros or something?
i know most tires like for example 205/70 R 15's usually have a whitewall on one side. u can probably get a set of those and just turn the white walls to the outside. I think 205/70 r15 would also look fine on ure car. the 205-70 and the 215/65 are only have like a .2 inch sidewall differnce. i just deiced on 215/65 since it was a tad bit shorter. but both would look about the same. My car is stock, no hydros or bags.
1 - 20 of 23 Posts
