1 - 10 of 10 Posts
drop passenger side ... lift front end....
if your car is set up right it will work
IVE GOT 3 PUMP AND I JACK THE CAR ALL THE WAY UP AND THEN DUMP MY RIGHT REAR AND IT ONLY GOES DOWN A LITTLE. AND I HAVE 10 BATTS IN THE TRUNK. SO I DONT KNOW
to get one rear cylinder lock all the way up and the other one with no pressure, pull a lift all 4, drop one whole side, then tap the rear switch again for a sec, then dump the same side again, this puts all the fluid in the stroke thats already extended.The lift the whole front and dump the front whel that was lock up in the first place. Just watch it though.If it unweights like you want it and your on a hill, you car will roll off.
Not sayin it will work,but thats the wbest way to get the rear end as stiff as possible
need to match the weight. less weight's in the trunk. power 3 wheel it sitting on the hood . then lower the front cylinder opposite
1 - 10 of 10 Posts
