1 - 20 of 80 Posts
why cant u use 2 pumps and 4 dumps to do a standing 3 wheel with a chainbridge dosent the dumps give u independent action on each wheel with this set up???
It gives you independent dumping but, not lift. The way a chainbridge is setup one cylinders lifts while the other dumps.
Originally posted by impala_631+Oct 3 2003, 08:47 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (impala_631 @ Oct 3 2003, 08:47 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--dreday@Oct 3 2003, 06:27 AM
You can still do a standing 3 w/ 2pumps & 4dumps.
u can stand3 with only one back pump but it would because of the weight disstubution
the only right way for a chain bridge to work is to have 2 rear pumps[/b][/quote]
TRUE, my regal can stand 3 all day, 2 pumps, 6 batts :cool:
Originally posted by BigNasty85Regal+Oct 3 2003, 10:06 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (BigNasty85Regal @ Oct 3 2003, 10:06 AM)</td></tr><tr><td id='QUOTE'>
TRUE, my regal can stand 3 all day, 2 pumps, 6 batts :cool:[/b][/quote]
bignasty,
how are your batts installed on your trunk? 3 along each side?
Originally posted by viznic+Oct 3 2003, 11:17 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (viznic @ Oct 3 2003, 11:17 AM)</td></tr><tr><td id='QUOTE'>
bignasty,
how are your batts installed on your trunk? 3 along each side?[/b][/quote]
;) YES, along the fenders, with pumps in the middle of rack :cool:
:0
Originally posted by impala_631+Oct 3 2003, 11:42 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (impala_631 @ Oct 3 2003, 11:42 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--BigNasty85Regal@Oct 3 2003, 10:30 AM
:0
i dont see how that could make you stand3 all day, my freind has 4 batts in one corner and it doesnt even come close to standing a 3[/b][/quote]
ALL I CAN SAY IS THAT IT DOES!!!!!!!!!!!!!!!!!!!!!!!!! :0
** If you need further proof that it does you should take a pic of it then ....... I can confirm that it does a standing 3.........What the sam dickens is going on with everybody here "BigNasty" ?? My 64 did a 25" standing 3 with 14" cylinders with ease & just about 21" with 10 rear cylinders .... Coill over setup w/ 4-5 turns on the springs....... Thats about it .. its how you pump & dump it ... all up , down on one side, lift the front back up .....Standin 3..
do it in a datsun!!
i know how to three wheel a car, im saying that its hard to do standing 3 with a regal with only 3 batterys to each side,the trunk is way smaller than a impala
In Due Time!!!!
bignasty, do you have a chain bridge?
BigNasty, I got the same set-up in my 85' Monte w/ 8's in the front and 12's in the back and I still can't stand on 3. What's up w/ that?
do what he says about trying to dump one side and raise the front, ive seen it before, it doesnt always work though. you gotta have the weight transfer, i dont care how you hit the switch
my 60 impala did a standing 3 wheel before on 8 batteries en 2 pumps , 4 dumps now I have 4 pumps and it puls his 3 wheel more easy ....
Is it alright if I do a standing 3-wheel w/out having any frame work done, or will the frame start twisting evetually?
Super Triple Double OG OG
no frame work equals frame and body flex/twist.......
You can three with one pump, just depends on how the weight is placed.
Originally posted by BigNasty85Regal@Oct 3 2003, 12:30 PM
:0
My brother had an '84 Regal with almost the same setup as this one (6 batt. 3 on each side, 10" cylinders, 2 pumps 4 dumps, no chainbridge, and most importantly NO 3-WHEEL)! It is easy to 3-wheel an Impala or something with long rear overhang, but not a g-body or truck, unless you are turning or have it bridged. I won't get into what is incorporated in a chain bridge, but it works off pressure and power, not weight. Frame reinforcement is a must, unless you like bent quarters. :(
1 - 20 of 80 Posts
