starting a new bike
788 Views 26 Replies 13 Participants Last post by  TonyO
i really need some help... i wont to have my bike up to par... i need to know any thing from painting the bike, how would i go about making the paint job have that cany look... tips on how to make a custom fork.... thinks it would really help my school is letting me do this for a project so i wont to take advanteg of this oppertunity
1 - 20 of 27 Posts
:uh: fuck this im going back to building race bikes
use common sense.
primor, base , clear.
to make a frame: do stencil in cardboard, cut your metal 1/16 thickness, weld it in place, grind the welds, put putties, sand a lot , prime it, to see all the defect and redo the putties at the defect place, then re-prime, sand the primer, lay the base coat and after lay a couple of coat of clear
to make custom fender: do stencil in cardboard, cut your metal 1/16 thickness, weld it in place, grind the welds, put putties, sand a lot, prime it, to see all the defect and redo the putties at the defect place, then re-prime, sand the primer a little bit with grit 600, lay the base coat and after lay a couple of coart of clear
appearantly you do
the frame
weld in place
puttie
ready to prime
primer
base coat and patern
clear
hes goin to think you welded the cardboard :roflmao:
i use a bird cage stand to paint my old frame.
stop fuckin with the new guy. hes asking for help. :uh:
yeah but the shit gets old someone has to post a how to on this shit and keep it pinned :cool:
ok now that i have the frame bonded in the design that i have in place.... where do i get the paint from so i can get the candy paint look... oh and where do i get the puttie from?
hey mate....you can get putty or body filler from auto stores and places like that...im not too sure about the paint though...
good look my dude.... its just body filler....
wal-mart sells candys in a spray can. you should check that out. will save you money. :cool:
:nono: your going to have blotchs and tiger stripes if you use those
not true, not if you know how to lay down a good paint job.
the key is using the matching paint brands. dont mix the duplicolor "anodize it" with the cheap 99 cent clear and silver base. Ive made it work, it can be done.
if i were him i wouldnt even attempt a candy paint job
lil guy is talkn about the small 4oz from the makers of hok kandy model spray paint at walmart a key to laying down a decent kandy paint job is laying down a even coat of kandy, kinda hard to do with only 4oz of paint in each can
what you talking about mate?
1 - 20 of 27 Posts
