1 - 17 of 17 Posts
Since theres no sub forum for this question hopefully i can get some help here. I wanted to do a 2" drop an 85 regal but wasnt sure if there were certain springs that work best. I know eibach offers a 2" drop as well as OPGI offers a 2" and 3"....I plan on running air shocks in the rear. Any info would be greatly appreciated. thanks.
SPELL CHECK
I dropped my Regal with some 2" drop springs. I can't remember the brand, but I believe I actually bought them from JC Whitney. :dunno: The price was right, the ride was smooth, and it looked great rolling on 13s. :cool:
Air shocks :thumbsdown:
You can use 2" Lowering spindles for a S-10 and not effect the ride Quality! :biggrin:
Why shouldn't I run air shocks out back? Someone mentioned I should.
So just s10 spindles with stock springs and 2" lowering springs in rear?
Thats a sounds like a good combo!
Originally posted by CHELADAS75@Feb 2 2010, 02:32 PM~16489610
s10 front coils wil work perfectly.
really?
dont use drop spindles. you dont need them. they are a pain on small wheels unless you absolutely need them. they put your lower arm in the dirt.
for 2 inches you could use cut springs. maybe find a forum that will rcommend how much of a turn to cut off?
im getting two different opinions now. spindles or springs?
ttt
i will be rollling on 14's btw. would spindles still not be something I should consider?
2" is not alot. find some springs or cut the ones you have.
there's no good reason to use spindles for a 2" drop.
people who talk about the ride quality changing are not using facts. a 2" drop would be cuttin a fraction of a turn off your coil. you would notice a bigger different going from a 175-75 tire to a 175-70.
SPELL CHECK
:no:
The diameter of a 175/70R14 is 23.6"
The diameter of a 175/75R14 is 24.3".
The difference is only .7".
However, you are right - spindles are not needed for a 2" drop.
Like I said, just buy some 2" drop springs. They're cheap as shit. :cool:
Discussion Starter · #13 ·
well i seen a set of 2" drop springs for cheap on ebay, ill probably pick them up. im on 14x8s with 175/70/14, btw. thanks peeps!
SPELL CHECK
:wow: Is that a typo or real?
Discussion Starter · #15 ·
real! not possible? i shouldnt say im on them, because they are still getting refurbished....but thats my rollers!
I have lowring springs for sale, avco and a ew other brands, Used but lightly
SPELL CHECK
Just not that common is all. Most people roll 7" wide wheels. :cool:
1 - 17 of 17 Posts
