aight, i had to swap..
imma try to remember..
disconnect battery
first use a steering wheel pull to take the steering wheel off, after youve removed the steering wheel cover, wires, etc..
i think i remember loosening somthing up under the hood where the steering shaft goes into the rubber sleeve..
OH yea, you need to disconnect the shift linkage under the hood next to the firewall, you'll see its a bracket coming off the shaft that has a rubber grommeted hole connecting to the shifter link going to the trans.. disconnect it, i forgot how it was easy though.
take off the lower dash panels to easy access..
theres like 3-4 bolts that hold the steering cover onto the firewall, locate em and take em out, just follow the shaft to the firewall and you'll spot em.. Might have to take off the firewall sound dampener rubber/cloth surrounding and covering the plate bolts
disconnect wire harness to the turn signal should be a long rectangle style connector, might be another connector somewhere to unconnect.
disconnect the shift indicator wire connected from the dash guage panel and under part of column, you'll see what im talkin about.. just pull it or slide it off with a screwdriver
unbolt the 2 bolts holding the column to the dash, if everything is disconnected, you should be able to just pull it out.. be careful, it can be tricky
while your at it, throw a steadfast column protection plate on it..
