1 - 13 of 13 Posts
my 87 regal has a tilt wheel and it some how has became very sloppy! i can pick the wheel up about and inch and move it about. whats the problem?
my old man said it was a pain in the ass to get inside the colun where there would be something broke....THIS SUCKS
My cutlass was doing the same thing :(
The repair shop wanted a grip($) to fix it too
My Dad said to go to the junkyard and find one there....So I did and got really lucky cause I found one in perfect shape and the same color too(It was from a 4dr cutty ;) )
So now Im straight :biggrin:
Go to your local yunkyard and good luck :cool:
im sure i could just repair this one
Originally posted by 1morecutty+Jan 3 2004, 09:52 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (1morecutty @ Jan 3 2004, 09:52 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--Mark@Jan 3 2004, 08:46 PM
Just trying to give you options :biggrin:
Good luck :cool:[/b][/quote]
i know, and thanks. but i have seen the g-bodys at the junk yard....a little less then nice.. :thumbsdown:
i have fix this problem in a few different cars. there are four bolts that hold the nuckle for the tilt. those bolts come loose you just need to pull the column apart and tighten them
Super Smasher
^^^ he's right on the $$ ... really easy but a real pain in the ass also....take the wheel off, remove the turn signal & light mechanism, and the lock cylinder, then lock tight those 4 bolts and cranck em down thats about it. :0
Discussion Starter #13
i found 2 screws that where loose...had my dad (much bigger man than i am) crank them fuckers down. i guess there is 2 more screws...i couldnt see them... but its back to where is used to be
1 - 13 of 13 Posts
