1 - 8 of 8 Posts
any 1 every take there wheel off on a 93-96 fleetwood with the air bag need to fig out how to lookin for some help thanks bro's
with most cars you either take the airbag fuse out or find its power source and disconnect it so it dont blow up in your face then theres screws on the backside to take the bag out of the wheel once youve done that you just tah the nut clip off unbolt the wheel and use a steering wheel puller to pull the wheel off the column the puller is a tool you can get at most parts stores and cost 10-30 dollars
you always disconnect the battery for at least 20 min. before you take the bag out, and static electricity off you can set upp the bag, so keep it pointed away from you when you hold it.
Originally posted by $Bigg Money$@Nov 16 2003, 02:15 AM
take the battery off or just the fuse out what makes the explosion is it all in the wheel??
you need to disconnect the battery for at least 20 min. to let the Derm (airbag computer) to lose power then the only thing that is going to set the bag off when you take it out is static electricity. It only takes millivolts to fire the squib in an airbag firing module.
Originally posted by skandalouz@Nov 16 2003, 09:58 PM
nope, but I've seen one go off when the idiot put it down beside a welder that was left on!
LOL is there some1 that crazy out there lol
1 - 8 of 8 Posts
