1 - 5 of 5 Posts
i have a 75 caprice and just installed a new head unit. every time i shut off the car and start it back up i have to turn on the radio power again and set it up. where do i connect memory etc. if the stereo only has power and ground going to it? im stuck
2GUNZ
There should be one wire going to the battery, and the other should go to a ignition on wire.
83 Cadillac Coupe Deville 3 pump 8 batteries
run a wire to the fusebox, above your left foot when driving. there is a terminal you can plug into, it's called bat or clock or somethin like that, anyway just put a spade connector on a piece of wire and plug it in and your good. Chevy actually put in terminals so you could add shit, it was cool.
1 - 5 of 5 Posts
