1 - 11 of 11 Posts
i will be buyin the stuff to bag my burban shortly and i need to know if i can use 3/4" valves for inflate and 1/2"for dump i need to be able to adjust it easily cause it will be my daily for a little while .will this be the best way? dodo this can i just put adapters on the tank or is there something else to do this.
you can use anything you want to dump and anything to pump psi ratings need to be followed you can lock up a dump valve if you are running a higher rated up valve not common unless running high pressure but you can get mufflers for the dump and put an extra fitting with a lil piece of the d.o.t. line out the dump reducer fittings
BeerMonkey,
I was worried about the same thing as you. I have been told that with a 1/2" system running 150psi it will raise/dump quickly. You can fit restrictor valves on the dump solenoids to slow things down a bit, so that your car doesn't crash to the ground :0
216rider has fitted smaller outlets to his dump solenoids to slow it down a bit. He has more restriction on the front - I think because of the car's weight distribution. He also has a video clip somewhere that you can download and it shows his car in action on an all-1/2" system running 175psi.
He'll probably read this quite soon and give you some proper advice.
yeah I'd say 3/8s up and 1/2 down, cuz yesterday i b umped my setup up to 240 to hop it and I had a hard time getting the bitch to come down fast enough, as for raise it gets right up, but my next step is going 1/2 all the way around instead of 3/8's valves
i use 1/2 front 3/8 back for weight cuz back isd freakin light and in front i put ball valves on the dumps to fully open if i want to show off or to slow it down if i don't want to worry about it and just daily driving but i have to have slowdowns cuz frame is freakin heavy an car lays it to the ground and makes a big boom
Face Puncher
smaller drops or reducer bushings?
either way will work.
I'm sure 3/8 valves are cheaper than 1/2's... so thats something to consider..
but on a burban, I would definately go with at least 1/2" ups
yea true the front of a surburban is big and heavy so 1/2 is good enuff
1 - 11 of 11 Posts
