Reds 1/2 ton coils were the best. I have about 15 sets of yellow 1/4s, 1/2 orange, and 3/4 ton blue,,and 3/4 ton red from prohopper
1/4 tons have too small an inner diameter to fit around mid size cylinders and you would not want to use a skinny regular cylinder.
Depending on how you do your setup, 1/2 ton would be the best. If you just cut the strut in half and do it the half ass way, then 1/2s fit nicely around a cut in half strut.
I would not suggest using springs, but if you insist then I would suggest doing the strut the way I completely rebuild them, using reverse flows. I never use springs, but I can add springs in my design with no problem. None of the Mac strut cars I have ever juiced ever had a problem. Some of them 3-wheeled though, against my recommendation to the owners.
I hate seeing Mac strut cars, because very few people know how to build the struts 100% safely and make ride perfect as well. A lot of mac strut cars can get a full stack of coil in all the way around and still lay low as hell, but most people don't know how to do it
[email protected] at Oct 9 2003, 02:22 PM
