Theres one thing I cant seem to get a straight answer on,
If I swap out ONLY the spindles on a g-body to caprice spindles, using the same coil and same g-body a-arms, will the car sit higher than it did with the g-body spindles when dumped out? Is the camber change more or less drastic through out the travel?
And will it bulldog the wheels out more? if so, is this just because of the upper a-arm sitting higher at the ball joint?
Also, what other options are there for spindles and a-arms? 70's full sizes,trucks,etc?
I just wanna know before I go to the junk yard and pull a bunch of parts I end up not wanting.
