both rearends are the same but im trying to put 1 off a cut car with cylinders under a stock car and i would like to know what all needs to be done so the cylinders can go straight through the trunk like do i need to cut anything on the frame for the cylinders or what cause im not doin a bridge on it yet?Originally posted by BBIGBALLING@Mar 20 2010, 02:50 PM~16946202
how was the other rearend setup please give detail information for help are you just now installing your setup. Or do you have a setup and just changing rearends?
I would love to hhelp but just need more information please!
Are the ears those 2 hole looking things in the frame and what should i cut them with?Originally posted by bounce13@Mar 21 2010, 09:16 AM~16951573
all you have to do is cut the holes in the ears so the cylinders will go throught and everything else should hook up just fine
thats them and use a hole sawOriginally posted by STLGHOUSEKID@Mar 21 2010, 01:06 PM~16952644
