21 - 40 of 40 Posts
Originally posted by M-827+Apr 10 2004, 04:08 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (M-827 @ Apr 10 2004, 04:08 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--skandalouz@Apr 10 2004, 01:08 PM
the extensions would not fit
Crap extensions then? Or crap switches?
It's one or the other, so with that in mind:
:twak:
Mike
:cheesy:[/b][/quote]
:machinegun:
Discussion Starter #22
Originally posted by skandalouz@Apr 10 2004, 06:19 PM
:machinegun:
Originally posted by M-827+Apr 10 2004, 05:48 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (M-827 @ Apr 10 2004, 05:48 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--skandalouz@Apr 10 2004, 06:19 PM
:machinegun:
[/b][/quote]
damn, you are one ugly mofo! :uh:
Discussion Starter #24
That wasn't a photo I sent you, it was a mirror.
:twak:
Originally posted by M-827+Apr 10 2004, 06:52 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (M-827 @ Apr 10 2004, 06:52 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--skandalouz@Apr 10 2004, 07:03 PM
:twak:[/b][/quote]
If I had a shaking head smiley I would use it! :uh:
Discussion Starter #26
Yes, I have noticed your propensity for smiley usage. You must be lost when you have to communicate in the real world.
:uh:
Originally posted by M-827+Apr 10 2004, 09:00 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (M-827 @ Apr 10 2004, 09:00 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--skandalouz@Apr 10 2004, 09:44 PM
:uh:[/b][/quote]
I prefer to use buzz's and click's!
Sometimes I just use my fist! ;)
Discussion Starter #28
Likewise.
Discussion Starter #29
:cheesy:
Hit up dreday on here. He's got extensions.......for hydraulic switches though:biggrin:
Not really. He'll probably be able to help.
Holy Molly. My screen won't even read this old shit..
For real go to Baskin robins or a milk shake shop and get you sum straws.. cut a little longer then the extention and all good. very tight free fix.. !!!!!!!! :biggrin: doing that for years. Better then tape . so you can pull them back off. Even on allen screw ones. they tend to go on weird. so take screw out and do straw. puts it on good and straight...
Custom Aluminum Toggle Switch Extensions & Door Locks Exclusively for Car & Truck Enthusiast.
Handcrafted High Quality Aluminum. Mid Length equip with Set Screws to Secure a Tight Fit.
I've been fiddling around with my new switches and switch extensions and:
How the hell do you keep the switch extension in the right place?
You can't do it up too close to the switch mounting because it will foul against it, and also, due to the shape of the switch toggle (narrower towards the switch), the extension tends to slip inwards towards the switch and wobble around annoyingly. The grub screw isn't doing up against a level surface.
I was thinking of trial-fitting the extension, doing the grub screw up tight enough to mark the switch toggle, then using that as a marker and grinding a recess into the toggle so that the grub screw sits in it.
What do you think? Dan? Anyone else with these switch extensions?
Mike
Checkout FAMS For All My Switches. Set screws keep their custom toggle switch extensions from falling off and always stays in place. Tightens with hex key which they included.
21 - 40 of 40 Posts
