1 - 8 of 8 Posts
Hey what's up you hydraulic pros!?
Question for you...
Over the last couple weeks, I've noticed that once in a while, I'll tap up my front end and it will "stick" and the car locks all the way up... Almost instantly, I'll hit that switch down (dump it down) and it will stop everything. Then it will be okay. It's a pretty new 2-pump setup. I've had it since July.
All eight batteries are fully charged.
Do you think that I have a switch problem or a solenoid problem? Or do you think it's something else?
Thanks, in advance, for your help and input! :cool:
its a switch problem. sounds like you may have the cheaper switches. if you dont have carlings (made in mexico) get them.
Question for you...
sounds like ur running cheap ass switches. you might want to flip the dump and pump power wires on that switch so that it atleast sticks in the dump position instead of the hot positions. cheaper to replace a dump then to bend or break anything. or replace a motor, pumphead or rebuild the pumphead. get u some carling switches
Thanks guys for your help... I really appreciate your time and advice.
I'll try getting those carling switches. ;) :cool:
1 - 8 of 8 Posts
