I need to re-wire my switch panel to my pumps,4 switches never wired before. Im trying to wire Fron, Back, Left Corner, Right Corner. Explain to me how if possible draw a diagram please....thanks guys
single pump buy the way,one front one back,one dump up front two to the back 6 batteries six noids
so you have one front pump with one front dump, one rear pump with 2 rear dumps?
then you have 6 wires to go to the front.
your 4th (rear right) switch is gonna have the rear noid wire going to one side, and the rear right dump wire on the other end.
your 3rd switch is gonna have a jumper from your 4th switch (noid) on one side, and the rear left dump wire from the trunk on the other side.
your 2nd switch (back) will have a jumper from your 4th switch (noid) on one side, and jumpers from both the 4th and 3rd switch (dumps) on the other side.
your 1st switch will have the front noid wire from the trunk on one side, and the front dump wire on the opposite end.
