Status
Not open for further replies.
I'M CONFUSED I PLAN ON USING 4 3 PRONG SWITCHES SO EACH WHEEL IS CONTROLLED BY A SWITCH BUT I THOUGHT ALL U GOTTA DO IS WIRE THE SWITCH CORRECTLY AND THEN MOUNT THEM ON MY DASH RITE. BUT IS A CIRCUIT BOARD NEEDED IT LOOK LIKE IT, ITS THE ONE I SEE IN THE SWITCHBOXES AM I CONFUSED OR WHAT??? :uh:
Don't know what you are talking about with the switchboards.
For four switches and four pumps.
EZ: The 24 volt wire throught the middle
the pump wires on the bottom
the dump wires on the top
Simple as pie.
Hope this helps.
Later
TC
look in that pic u will see the switch sits on a circut board or whatever do i need one of those or its like i can wire the switch like tc said then drills holes in my dash and just let it sit there???
That is a switchbox that is not normally used. That company made this box with a circuit board. Normal switch boxes have just switches, no circuit boards. Just have an experienced installer do your set-up and they will take care of what you need...
Status
