what can i use to cut off the 24volt power to the switches. another switch??? i've had dump coils burn overnight because of a bad switch giving it power. pics are appreciated. thanks to everyone in advance.
could always inline fuse it and just remove the fuse when not in use, thats what im gonna do
Trevor
All it requires is a simple on-off toggle switch on the 24volt line.
All the boxes I make have these. If it saves your switches once, it's all worth it.
The switches are only a few dollars.
later
TC
this is sorta hard to explain but you can get a 6 pin or 9 pin computer disconnect.........
i am going to wire mine this way in the caprice.........i will pull the disconnect and hook it up to a single switch for hoppin...........
i bought the disconnects already and radio shack they were only $2 a piece...you need a male and a female..........
good luck
