I WAS BROKE THE OTHER DAY BUT I NEEDED TO MAKE A NITROUS BOTTLE FOR MY INTEGRA SO I MAD MY OWN IT I CAM OUT GINUWINEHERE IS HOW I DID IT:
MATERIALS:
1. ONE BIC INK PEN THE CHEAPS ONES U GET FROM PEOPLE AT SCHOOL
2. X ACTO KNIFE
3.SMALL BRASS TUBE
OK TAKE A PIN AND BITE THE PART THAT U WRITE WITH TO REMOVE THE INK THINGY THEN WHEN U ARE DONE WITH THAT MEASURE ABOUT A INCH UP AND TAKE THE XACTO KNIFE AND HEAT IT WITH A TORCH OR LIGHTER TO GIVE U A CLEAN CUT DONT USE A DREMEL CUZ THEY ARE TO BIG AND U MIGHT F UP SOME PINS BUT AFTER THAT TAKE A DRILL PUT A SMALL DRILL BIT ON IT ABOUT THE SIZE OF THE PIPE U BOUGHT AND DRILL A HOLE IN THE BOTTOM OF THE PIN CAP THEN CUT THE PIPE TO A LENGHT THAT IS SMALL AND GLUE IT IN THE HOLE WITH ABOT A 2/16 OF IT STICKING OUT , AND FOR THE BOTTOM OF THE TANK USE PUTTY TO FILL IN THE HOLE AND SAND IT TO IT FLAT ON THAT END THEN CUT A VERY SMALL SCREW AND GLUE IT ON TO THE END OF THE PIPE AND DO SOME OTHER DETIAL SHIT IF U WANT THEN PRIME IT AND PAINT IT VOLLA U HAVE U A NITROUS TANK AND U DIDNT SPEND SHIT FOR THE ONE DETAIL MASTERS SELL
MATERIALS:
2. X ACTO KNIFE
3.SMALL BRASS TUBE
