True-S Mike
leave it on the pump, connect it to the first battery in your sereis( 12 volt ) with a jumper cable. plug in ground. if it makes a sound/lifts the car it good, if nothing= bad
do it off the pump just use the bolts to the pump and some 1/4 20 nuts and make it tight end cap to motor end cap hold the motor down ... and throw 12 volts on it with jumper cables ... it should have plenty of snap ... and spin quick when hit ..
Do like Juggalo said. or take a volt meter and see if you get power to the motor when the switch is hit. If you don't, trace back in the system untill you find power.
If you do have power to the motor, then you should pull the pump out and see what the problem is......
