1 - 20 of 28 Posts
How do you test solenoids? If you want to check and find out which one is messed up, i got three per pump for example. I know its a solenoid, because batteries have been tested and all are good. I get a click when i hit the rear switch and that's all. I would assume no one replaces all three, there must be a way to check one by one to see which one is stuck. Anyone want to give me a how-to???
GOFUCKURSELF
Cheap ass, replace all 3 :uh:
Why do that, just let him replace the 1 solenoid and the others will soon blow next or get stuck and burn up his motor, or blow the seals in the pumphead or pressure seal..or both seals maybe even a shaft seal then oil will get into the motor and possible catch fire...
GOFUCKURSELF
:cheesy:
Phoenix Chapter President
:roflmao: :roflmao: :roflmao: tell 'em... :thumbsup: If one is bad the other's are not to far behind it......
Real Rider
LMAO. If he didnt get the point, I sure did. Im never replacing just one again. :biggrin:
yep learnt the hard way replace all in that bank
learn how 2 use a multi meter, honestly with lowriders i personally believe it is only a benifit if you are familiar with them,
theres alot of nolan ryan parts pitchers out there better to know what the problem is than just pitch parts at your setup trust me go buy a cheap craftsman meter and learn this stuff
use the ohm scale with audio so when the noids click you hear a beep telling u its good
Banned
:uh:
sometimes the bad one will sound diffferant.
I just said this in a different topic, but doesn't it make sense that if power is going through to the motor, that all of them are stuck? If only 2 are stuck, the 3rd one will still disconnect power, right?
Or am I the retarded one? never got why solenoids were ran in series anyways.
yup all 3 need to be stuck to get power to the motor, its a god idea to ohm them out for the seaon to check
what I never really understood is why both contacts in the solenoid are made from the same material(copper) couldnt they make it out of 2 different types of materials that dont stick together,..... :dunno: maybe cost of production???...
GOFUCKURSELF
Or am I the retarded one ?
:rolleyes:
GOFUCKURSELF
Accumax , posts are copper, contact plate/ washer is plated
Real Rider
So how again do you check for the bad ONE?
:dunno: :dunno:
GOFUCKURSELF
:dunno:  :dunno:
Disconnect ur main power to the noids. Test the outer main contacs using ohm meter. Should read infinite. Now have someone tap the switch, should zero out on the meter. This is if they r good. If they are stuck, u will get a zero reading without tapn the switch...
he didnt say they were stuck, just a click sound .
1 - 20 of 28 Posts
