I have a '79 Caddy with a two pump set up, the back works fine and the front was working perfectly until two days ago. I lowered the front all the way down and when i tried to raise it it didn'y even make a noise. Is it a bad selenoid? You hear a click but only if you hit the switch downward not up. Is there a way to adjust manually so at least i can drive it?
