1 - 20 of 58 Posts
depends on the setup. If it's real stiff and bouncy than its going to be a long ride. If it can suck up pot holes I wouldn't wory much
was told it was solid the frame is renforced
Moderator
I drove my Lincoln from LA to Lexington KY. I did put stock wheels on though. That was 6 batteries, coil under in the rear, not super stiff springs. Didn't have any problems.
:cool: kool if it happens it will be from cali to chi im worried about the mountains
Originally posted by Lord Duez@Feb 10 2010, 09:32 PM~16576789
The roads are paved through the mountains. :uh:
thanks i didnt know that.............................................oh yea this aint offtopic
Member # 1,077
i drove my cadillac on 14's and no accumulators from hartford to los angeles and it was fun. only problem i had was the chip in my distributor went out on virgnia...
i figured just take my time and i should be :cool:
Moderator
Yeah you'll be good as long as the car is up to it. Just set the car at the right height where it rides best and you'll be straight. We stopped for 3 hours in the middle of the night, but other than that drove 45 hours straight.
Discussion Starter #11
if i do im gonna have a co pilot so i plan on not stopin except gas and stuff like that
stock wheels really helps. how many batteries?
Discussion Starter #13
9
If your car rides low throw some bigger coils in there,if something happens like a check or dump going out you would still want to be able to drive safely with it dumped out...
~Maniako Enfermo~
Originally posted by chicaddi@Feb 10 2010, 08:32 PM~16577432
9
With proper engine and car maintenance it should be a nice ride... your tires might wear pretty bad if you're not at a good height.. I've heard that the mountains are tough on engines.. many vehicles tend to overheat.. because of the strain and lack of air..
Discussion Starter #16
its a v-8 low miles
Member # 1,077
Originally posted by chicaddi@Feb 10 2010, 10:58 PM~16577847
its a v-8 low miles
14 or 13's?
~Maniako Enfermo~
Originally posted by chicaddi@Feb 10 2010, 08:58 PM~16577847
its a v-8 low miles
that's cool jest make sure to check the fluids.. and good luck.. i don't mean that in a bad way..
wow, now that's a road trip!! how many days did it take?
1 - 20 of 58 Posts
