1 - 15 of 15 Posts
I am currently redoing my air suspension setup for my car, (I used telfon tape).
HOwever; people have been telling me to use other things like putty dope, thread sealant..... etc..
In your opinion, what should I use?
i uaually use tape works fine just don't go past the first threeads or get tape into the end of the threads
the tape will fall off inside and get stuck in the valves and cause small leaks and missfireing valves sputtering and parting valves
tape should be fint though
[snapback]3456760[/snapback]​
I used to get that, be going nutts taking it all apart and shit for NOTHING!!!!
Originally posted by joebomber52@Jul 22 2005, 10:36 AM
but most quality fittings have the sealant on them already
one that i use never give me problems is #2 non hardending form a gasket
[snapback]3457125[/snapback]​
none of mine did. I got them from off places though. I started to use wack ass teflon, but I'm starting to wonder if there's a #1 rated type.
Originally posted by joebomber52@Jul 22 2005, 10:51 AM
when ever i used teflon i just used the basic 1.00 pack of 10 from home depot
[snapback]3457284[/snapback]​
same here, but I think the ones I got went bad. I opened one up and the tape was all warped, but then again it was a hot day but still.
Originally posted by snko916@Jul 22 2005, 02:35 PM
Okay,
I tried Liquid telfon : '"Great White ..."
Didn't hold anything.
When using Telfon,
How much do you use?
I used a whole bunch.
[snapback]3459207[/snapback]​
for me, I wrapped it around 6 to 7 times. You don't need to use a whole bunch as joe stated that the teflon will get into the thread and be forced into the valves.
Originally posted by b_diddy1@Jul 22 2005, 05:02 PM
This may be common sense, but there is also a right way to put this teflon tape. Doing it in my mind, you need to roll the tape on clockwise, with the end of the nut which goes in the hole facing you. If not, when you thread the bolt in, it will tear up the tape.
[snapback]3460085[/snapback]​
damn didn't think we had to bring in common sence but yeah make sure you are doing that too :biggrin:
1 - 15 of 15 Posts
