Originally posted by Joe5pt0@Aug 29 2005, 07:36 AM~3711566
I'm so confused. Was there a question in there somewhere?
oh yeah he did that
:0 looks like your distributor advance is 180 degrees out, try setting it around 26 28 at 3000rpmor 8- 10 initial
You might be confusing him...... :biggrin:
G
dude there all wrong a 350sbc has to be timed like this-pull the vacum off the dist. turn the dist. till it reads 8degres before top dead center then titing down the dist. bolt then hook up the vacum good to go
yea well, if your vacuum advance is only advancing it to 24* bdtc @ whatever*tdc initial timing, it may not be enough for your application!
pink63impala is dead on :biggrin:
