I drive a french car and on the front iS normal shocks and spring suspension but the back is torsion bar, will this effect the placement of hydros or will it not matter?
I'm taking it the rear has a swing axle style suspension. you more than likely are going to have to fabricate a bridge for up top and mounts on the trailing arms for some pro-balls. and just leave the torsion bars cranked all the way down so they have no tension on them!
im sure ive answed this a few times before you need to leave the torsion bars inplace BUT it is advised to remove the splines as to allow free rotation of the rear arm then replace the original rear shock witha ram i think its around 7" long ,havent you sdked this on lordz site before
any ways heres 1 done why not contact ray at www.rayvernhydraulics.com as he built the 1 pictured above
