1 - 20 of 31 Posts
Kiss Of Death
when i rented the tow dolly, the guy at u-haul said i had to disconnect the drive shaft or else the tranny was gonna burn up: is that true??? anybody ever tow with a tow dolly??? well if it is true, then i now need a new tranny, cuz i didn't do it!!!!
i already had to rig the car up with 2x4's as spacers cuz it was sitting to low to tow...so fuck it...i guess ill find out, when i try to drive it, huh???
I Towed my couisin's mustang from waco 3 year's ago
we did'nt do it too. he's still driveing the car
" work's fine "
Them U-Hual boy's just like the
AutoZone boy's
Dont know Shit !!!!
Kiss Of Death
" work's fine "
AutoZone boy's
Dont know Shit !!!!
yea no shit, huh???
anybody ever hear about this... :dunno:
SPELL CHECK
I don't know man, I've never heard anything like this before. Seems to me as long as you're in Neutral you should be fine. Think about all the people who use tow bars and dollies to tow vehicles. Seems like a lot of trouble to pull the driveshaft, and for what?
Super Moderator
I take the driveshaft off when using a tow dolly.
Super Moderator
" work's fine "
AutoZone boy's
Dont know Shit !!!!
was the Mustang standard or automatic? if standard, you just don't put it in gear.
whan the tow truck's take your ride them ass hole's dont
take off nutthing.
But they dont care about our ride's
put it in Neutral,Neutral,Neutral,Neutral,Neutral if you didn't and travel for a while your fucked....
Kiss Of Death
ey latin, were you told to take it off...or did you just do it from past experiance???
Super Moderator
past experience and also was told years ago by people. had a transmission start to slip due to a long haul once. ever since then, i take the time to take it off even if it is towing locally.
Kiss Of Death
it was only like a 3 hour tow...if it fucks up...oh well, fix it right??? :biggrin: :biggrin: :biggrin:
i remember couple years back dude was towing his truck to phoenix on a dolly. soon as he took it off the dolly his tranny was done. better safe than sorry
Take the drive shaft off during a long haul...anything over 20 to 30 miles. After about 20 miles there could be significant damage due to the transmission over heating. The transmission fluid pump is operated by the flywheel...if the motor is off, no fluid is moving around in the transmission. If you remove the driveshaft the gears in the tranny will not move so your good.....but if the driveshaft is left in place, the rear end will turn the drive shaft and the rear unit of the tranny. Is it likely to happen....no not really....but its better to take 15 mins and drop it then to risk spending hundreds on a rebuild. As for the comment made about tow hitches and tow vehicles....almost all of them are 4 wheel drive which is a totally different lubrication system and those that are not have a "self lubricating system" added on to them. Even at that, it is still recommended that the tow vehicles be turned on after about 200 miles to relube the tranny. Hope this info is helpful......
Arthur Solis
soliscustoms.com
Arthur Solis
soliscustoms.com
That's exactly what I was told too, and not by Ryder's/Uhaul but by a mechanic that worked on my cars.
1 - 20 of 31 Posts
