1 - 10 of 10 Posts
ok peep it i bought a lil pint full of auto trans conditionoer to dump into the trans. neways i was lookn for the dip stick and couldnt find it. so i was reading my owners book n the arrow pointed to the left valve cover. there was a plug that i pulled out and dumped the fluid in there//// where the hell does this hole drain to ? intot he oil? what should i do?? imma flush then oil tommrow??? what was this plug 1994 towncar v8
tranny fluid will clean out your engine it wont hurt .if you put oil in the transmission that tears sh** up. drive a little and change the oil
DO NOT LISTEN TO THIS^^^^^^^^^^^
I seen people pour a LITTLE tranny fluid in their carb with the throttle up but you DO NOT put it in your oil & drive ANYWHERE.
He's right, it will clean the motor. Just run it for a few minutes, drain it, run a fresh quart of oil through, plug the pan, and add oil. :biggrin:
Originally posted by schmidt64@Jan 17 2004, 01:35 AM
it is used sometimes to clean out combustion chambers by burning with the fuel, not by adding to the oil. get it out of there.
fuck i have used it in a old regal that i had ....the lifters started ticking..i put just a small amount of it in there.... im talkinga bout a couple of cap fulls though.. in to the engine oil..then i drained it out ... changed the oil and the lifters where cool...
tranny fluid will not hurt a motor in the oil.it cleans the gunk out of it .ive even run deseil fuel through them on gunked up motors.tranny fluid is good to run everyonce and a while in the oil
1 - 10 of 10 Posts
