I want to trade for G-body chrome rear end or brake system calipers,rotors,etc..and am open to other trades just let me know what you have.I could also use 2 amps i'm not too concerned of what brand but i have to at least have heard of it and they have to be of the same brand 600w and higher.If you have screens available then they need to be headrest screens or one pretty good sized screen Visor Screens a +++.I am alos open to other trades that are not related.
This Thing Can Give You a 21 Foot Screen for your Xbox 360/PS3
Product Features
0.55-inch DMD DDR projection technology
800 x 600 SVGA native resolution
High 2,000:1 contrast ratio, 1,100 lumens of brightness
4:3 aspect ratio, supports 16:9; 2.5-watt speaker
Supports NTSC, PAL, SECAM, EDTV, and HDTV signals
Technical Details
Data compatibility: SVGA, VGA, XGA, Macintosh
Display type: DLP by Texas Instruments: 0.55" SVGA DDR DMD
Native resolution: SVGA 800 x 600
Contrast ratio: 2000:1 full on/full off
Brightness: 1100 max ANSI lumens
Aspect ratio: 4:3 native (supports 16:9)
Projection lens: Zoom Lens with manual focus and manual zoom adjust
Image size: 2.7’ to greater than 21.6’ (0.8 m to greater than 6.5 m)
Projection method: Front, ceiling, rear
Zoom ratio: 1.2:1
Maximum projection distance: 9.8 m
Minimum projection distance: 1.5 m
Video compatibility: NTSC, PAL, SECAM, EDTV, HDTV (1080i, 720p, and 480p RGBHV)
Input sources: Video (S-Video 4-pin mini DIN and composite video RCA); Audio (Stereo RCA); Computer (VGA 15-pin HDDSUB female)
Light source: 150W SHP/4000 hours
Menu languages: English, Norwegian, Spanish, Italian, Portuguese, German, French, Chinese (simple), Chinese (traditional), Japanese, Korean, Russian
Contol: Projector keypad; IR remote contro
Keystone correction: +/-20 degrees
Audio: 2.5 Watt mono
Power consumption: 200 watt typical/250 watt maximum
Power supply: 100V – 240V at 50 – 60 Hz
Dot clock: 20 to 95 MHz
Audible noise: 37 dB
Width: 9.8 inches
Height: 4.2 inches
Depth: 12.5 inches
Weight: 6.8 pounds
Product Features
Technical Details
Zoom ratio: 1.2:1
Width: 9.8 inches
Height: 4.2 inches
Depth: 12.5 inches
Weight: 6.8 pounds
