on my 63 w/ powerglide any ideas it has fluid
is the kick down rod hooked up ? to the carb and the tranny? if not this will keep it from shifting if it is make sure its adjusted right
this happened when i was working on my starter the other day... the transmission shifts are apparently based on a vacuum line that goes to the transmission... i'd accidentally disconnected it, so it wouldn't shift out of 1st... i connect it, and it worked right away ;)
