1 - 3 of 3 Posts
hey i have a fewe questions about a transmission its in my 84 caprice, i think the motor is a 305 but not too sure.. any ways would:
1.would the trans, still shift if the filter need to b changed?
2.my kick down cable (high gear cable) isnt workin rite. one day it would work, than the next it dont, so i cnt go fater tha 45 or so. i know the cable should go bak in place when you let off the throttle so it can down shift, but some days the cable has no spring like fill to it, which is y it dont come out of first gear.
well can some1 help me out?? ps give me any info, or suggestions pls thnks!
Q num 1) yea the tranny will shift, but it could also have problems
Q num 2) Check your tranny fluid, if ok then ,,,,, I belive theres a torque converter lock up switch ( solenoid) if there is , the connection will be on the dr side of the pan , should be like 3 or 4 wires on a plug on the side of the pan. . disconnect that plug and test drive it,.. If it work good then just replaced that part, but you have to drop the oil pan so you might as well change filter and fluid.. . Make sure to look for abnormal shavings, GOOD LUCK
1 - 3 of 3 Posts
