1 - 3 of 3 Posts
sounds daft i know but how on earth do you get the rocker panel covers back onto a regal ? the plastic oblong clips will only go on one way and i assume you hook one end on and then force the opposite end to 'click' into position.
Is this right ? are there any tips to make it less likely i'll damage or bend the trim ?
~Individuals CC~
Jon, I just did it this weekend.
The rockers on the doors, right?
After you get the clips placed, the spring goes up, you have to align the bolt holes on each end of the door. After putting the bolts thru the holes, press the rocker down to compress trim clips, and snap the bottom into place.
Easy.
1 - 3 of 3 Posts
