1 - 16 of 16 Posts
3 pumps 2 to the front 6 batts i hit the switch to dump and the right solenoid makes a click noise i run hd solenoids when i hit the switch up to raise it and both pumps make a bad noise kind of like a person clearing there throat just deeper !! Solenoids are grounded good battery terminals are tight i run a quick disconnect up to the front under my seat dumps are grounded and wired pumps are wired to the solenoid!!??
Your solenoids should not be clicking when you hit the switch to dump the car.
Bad wiring.
Originally posted by KCRIVI71@Aug 3 2005, 09:30 AM
rechecked wiring and its ok
[snapback]3533698[/snapback]​
Tap each battery individually to make sure they all have good spark.
Make sure there is no air in the hoses by bleeding them.
Is the car lifting at all?
buzzing sound= bad batt. single click=solenoids. no click= bad24vor 12v battery(what powers the soleniods-switch box).....
Originally posted by KCRIVI71@Aug 4 2005, 08:49 PM~3543774
the crazy thing is is that it wasn't a buzz sound it was more like a garbage disposal i run 6 batts in series and the bad ones were the 4th and 5th huh
garbage disposal= low fluid usially
1 - 16 of 16 Posts
