has any-1 here put them on a towncar.... the rim is hitting the caliper....we put on spacers and grinded down the caliper but its still hitting......any-1 know how much u have 2 grind b-4 they go on???
need info asap...car is outside on jacks
Originally posted by lowlow90@Jan 6 2004, 02:06 PM
grind the hell out of them they will fit
no they wont fit no matter now much grinding u do. u have to change the caliper, caliper bracket, and the rotor, as well as grind the tab off the brake line (theres a tab on the end of the brake line where it mounts to the caliper) the newer tc's have bigger rotors and calipers. u need to change it over to the 97 and earlier style. if u get one from a 90 its less grinding that 91+ ;)
i have an 03 lincoln ls and i had no problem fitting them at all.
i just put them on to see if they would fit and they did just fine
must have smaller shit then town car
