1 - 20 of 30 Posts
I have to change my A-arms for my 64 impala. I have not installed my hydralics yet "but its coming soon". Instead of buying the regular A-amrs will the tubular ones work for me? Will they stand the hydralics weight/pressure?
The Great White Hype
Originally posted by NY-BOSSMAN@Dec 11 2008, 11:15 PM~12405265
no good for hydro's
if they were made out of Chrome Moly with a thick wall, maybe
Originally posted by NY-BOSSMAN@Dec 11 2008, 08:15 PM~12405265
no good for hydro's
x2 i thought those were use for the donks cars :cool:
race cars too
the tubular arms would be more useful on a air bag suspension. not designed for hydraulic use, unless they were thick walled chrome molly arms but at that rate youd probably spend more than u though u would for a set lol...
SO FRESH!!!!!
why.... i could understand the loweres arnt good cause they take a lot of stress but the uppers don't really get any stress they basically just hold everything straight so why couldn't at least use the uppers
good words. :cool:
if you think the uppers dont get any stress than ask yourself as to why people bend un-reinforced A arms all the time
SO FRESH!!!!!
i guess but why is it fine on an airbag setup thay still have pressure and they still take a beating
only air bags i see taking a beating are ones running large compressors with huge tanks. if its just a simple bag setup its now running the kind of pressure hydraulics do. think about when u install a coil and cylinder in the front end. you have to jack up the lower A arm to meet the upper to bolt the ball joint in place. that there is already stress on the balljoint and arm. on air bag setups they usually lay frame in front. so you dont haev to jack up a lower a arm to meet the upper...u can just pick it up and put it in place...
1 - 20 of 30 Posts
