1 - 9 of 9 Posts
It has A stock amp in it and there is no way to hook up a stereo with the wires that came from the stock radio.With this bypass you get the correct
+ - power antenna wire and the speaker wires without making a giant mess or running new wires for everything
what he said. it makes it a lot easier having that in one package. that's a good price also because once you get a gm harness, ant adapt, and ant extension, not to mentioin speaker and power wire, that can add up.
in the trunk is the only place you will find all 4 speakers and the antenna.
DC
ok so one more question. can you fit a double din screen like this one. again its a 93 cadi bigbody. thanks everyone for all the help
Originally posted by Juiced10@Oct 11 2006, 08:30 PM~6350675
no shot to fit a double din..... use a single din or start cuttin if you want to fit a double
maybe its a different dash but my friend had a 91 fleet and a 96 fleet and both had double din tv radios without cutting.
im about to pickup a 95-96 model deville and it also has a double din dash. so i dont know
i found this. its in a 95 bigbody. the dash is exactly the same as the 93 right?
1 - 9 of 9 Posts
