1 - 3 of 3 Posts
the turnsignal stick came out of my impalas steering coloum
is their a way too put it back in without removing the steering wheel? if not what do i have too do in order too put it back in or do i have too replace the swith all together :uh:
help please
Well, the turn signal lever has a hole in the end of it where a screw goes thru and holds it to the turn signal switch inside the column Iits made of plastic).... did any plastic come out with the lever? If it broke off the plastic inside, it has to be replaced.... and you have to remove the steering wheel to do that.... but its not too hard.
thanks im sure no plastic came out when it fell out
1 - 3 of 3 Posts
